Computer Recommendations
   / Computer Recommendations #1
PitbullMidwest
Platinum Member
SE Iowa
1998 Kubota L2900GST
Hi All,
My Pastor is looking to buy a new computer and I thought I'd solicit some input from the brain trust.
He wants a notebook with these "must" have features:
a. the ability to display to a second monitor
-and-
b. the ability to output to a video projector to display powerpoint and video.
Price range under $1500, what are your recommended brands, etc.
Thanks for the help.
   / Computer Recommendations #2
I'm assuming you are talking Windows based. I would start with Dell, Toshiba, & IBM in no particular order. All make pretty decent machines with decent warranty & decent tech support. From my experiences I would stay away from H-P/Compaq and also probably Sony, but that is just my opinion. I've also known quite a few folks (companies) with Winbooks that had pretty decent results, though I'm not sure if they are up on the technology that they once were.
BTW, most all laptops can display to a "second" monitor - I'm assuming this is just in addition to the normal LCD screen. Projectors can also use the normal external VGA port. Some have S-Video output or RCA out, but personally I've seen the best results just using the normal 15-pin VGA output.
   / Computer Recommendations #3
I'm pretty partial to Dell myself as I have had good luck with them. If he has time, my suggestion is to keep an eye on the Dell website. I saved almost $1,000 on my setup for my laptop but I kept a close eye on the Dell website for almost a year. They offer different specials and they finally offered the special that had everything I wanted plus a few upgrades I added.
   / Computer Recommendations #4
I would go with the Dell. At work we run Dell, IBM and HP. Day in and day out the Dells last longer.
Right now I have an IBM machine and its a fight every single day.
I agree with Steve....keep an eye on the dell site or sign up for thier promo emails.
   / Computer Recommendations #5
Let's see..... Dell, Dell, and Dell. Those would be my top three choices. That's all we buy at work anymore because nothing else holds up. IBM is selling (or trying to) their computer operations to the Chinese. HP is also in termoil at the present time. Dell has the best business model and pretty much the best customer service if something goes wrong.
   / Computer Recommendations #6
I use to get HP's. But not no more. Now everything is Dell. Very few problems and when so the service is pretty good.
We have about 15 desk tops and 2 laptops.
murph
   / Computer Recommendations #7
Does display to a second monitor mean simply support an external montitor or does he want a second frame buffer to have to the internal display and exteranl display showing differant data? (true dual monitor).
Most of what your asking for can be found is most every laptop.
HP/compaq, dell will meet your price range on the high end.
Heck, Wallmart has a sub $600 laptop online with decent specs.
If your pastor is like ours, this is a MAJOR investment so go with the name brand and buy the extended support.
   / Computer Recommendations #8
hmmm ... don't know what the heck happened to my response from this afternoon .... but, anyway ...
the standard configuration these days for PC's (not Apple powerbooks, obviously) is to have WinXP installed and the standard XP setting is ready for multiple monitors. I use this on my IBM laptop daily. As well, almost every laptop you'll find will have a video port to allow you to use that external monitor or a projector.
If I recall, IBM sold their PC line to the Chinese ... excepting the laptops. We have about 40,000 of them in service and they seem to be working just fine. However ... you'll very likely get a MUCH better deal on a Dell and the quality is there.
Tip: to watch for a deal from Dell (or anywhere else) ... better than signing up at Dell ... check daily at techbargains.com ... they list all the deals as well as special coupon values and little know discount codes.
pete
   / Computer Recommendations #9
It is important for people to understand that Dell, IBM, HP, whoever.... Do not make computers or computer component's they only assemble them. It takes about 10 minutes to assemble a computer a note book maybe even slightly faster.
One reason that Dell has a good reputation is that they were in the right place at the right time. In other words as they began to heavily market there brand of computers component technology and operating systems (None made by Dell) became much more reliable and cheaper. So there is a perceived notion that Dell is better when in fact the difference in reality from one computer to the next is only the color of the case and of course the logo on the outside.
Now service is a different issue after all they are computers and 7 of 10 will need service of some type. Quite a high number for consumer electronics but it is the case. So as in tractors look for the best Dealer and the best deal. If you shop by service... well Good luck with that. I can tell you the odds are 99% you will be talking with some one from another land with likely very little experience and command of the English language.
Oh and by the way Laptops need repair much more often than desktops if they are used in the way they are designed (moved allot). And they are inherently less stable because the component's inside are not as mature due to the room allotted in the case. They change the parts allot to make them smaller. On the desktop size is not an issue so the focus is on making the parts well... hopefully better.
Good luck with your search
Thanks for the responses. When buying computers I've always spent as much as I could afford and bought more than I thought I would need. Since I've never owned a laptop it was a little more diffficult to make the recommendation but after your responses I recommended the Dell Inspiron 9200 with an upgrade from DVD rom to a CD-RW or DVD-RW
The overall project will include dual projectors for powerpoint slides and worship choruses for Sunday services and will be used by the Pastor on a daily basis.
Now all he needs to do is convince those on the board that think computers are a passing fad. /forums/images/graemlins/crazy.gif
Thanks agin.
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
