Computer CDROM Expertise...
   / Computer CDROM Expertise... #1
TerryinMD
Veteran Member
Sharpsburg, Md
John Deere 4100 HST
The Kenwood 72x Truex CDROM on my computer just decided to go south forever and I am a little miffed. Of course, it died a couple of months after its 1yr warrenty expired. /w3tcompact/icons/mad.gif
I tried the obvious like swiching the power supply connectors, checking the seating of all of the power and EIDE connectors. Pushed all of the buttons, poked, probed, and swore at it. To no avail... /w3tcompact/icons/sad.gif
I went as far as taking the back off to see if any bugs may have crawled into it to cause a short (remember the origin of computer bugs). Bag the warning sticker since the warrenty expired. No bugs.
The new hardware wizard cannot "see" it and I can not force a discovery.
Any other possibilities?
Or should I go shopping? If so, any recommendations?
Terry
   / Computer CDROM Expertise... #2
Is it still showing up in Control Panel-System-Device Manager? Is it showing up more then once?
Either way, remove it in Device Manager and reboot your computer. Hopefully, when it reboots, the OS will try to find the hardware. If you get the "Unknown Device", use your CD-ROM set up disk (you should have this disk handy).
The CD-ROM drive may have been lost in the BIOS. If you are familar with working in the BIOS, you'll figure it out. If not, reply here or e-mail me at home.
BTW, does the drive show up when your machine does the POST?
Roy,
Neither!! /w3tcompact/icons/sad.gif
As far as XP is concerned, it does not exist. Was there less than a week ago and then, kaput.
Terry
   / Computer CDROM Expertise... #4
By "Neither", I assume that means it's not in the BIOS (not showing up during POST) or in Device Manager...
In BIOS, you can try to Autodetect. As the machine first boots, you should see a message "Hit F1 to enter Setup..." or it may be "Hit Del..." to enter the BIOS. I don't know which BIOS you have, so once in SETUP you have to look around. If you have the manual for your MAINBOARD, read it first. The MANUAL will explain how to AUTODETECT your drives. If you don't have the manual and you've never worked in the BIOS, I suggest you take your computer in for service.
Since you already opened your case, did you try to reset the ribbon cable? It only has to be slightly awry to malfunction. If you have another ribbon cable, you could try that...the cable could be bad.
If you CD-ROM isn't showing up during the POST, it indicates more of a hardware problem to me. This isn't definately the case, but if it were driver related, I would think it would still show up (as a drive) in BIOS.
   / Computer CDROM Expertise... #5
<A target="_blank" HREF=http://www.kenwoodtech.com/>Kenwood Tech Support & Firmware Upgrades</A>
If you are still having problems, call Technical support at 1 (888) 730-4206.
Roy,
I've reset ALL of the cables, but I haven't tried to replace the ribbon cable. Worth a shot.
You mention hardware problem. I believe that the CDROM just died and went to CDROM heaven. What other hardware issues may be present? Bad motherboard? Since I moved the power connectors around I think I've eliminated a bad power supply.
JM,
Thank you for the Kenwood info.
Terry
   / Computer CDROM Expertise... #7
As a test for the ribbon cable, unplug the one you're using for you hard drive and replace it with the one for your cdrom (assuming they're on different IDE channels). If your hard drive works then the cable is fine/w3tcompact/icons/frown.gif. If it doesn't work, lucky you! (I've never priced a ribbon cable but it can't be that much).
   / Computer CDROM Expertise... #8
This is a long shot ...
Did you download any new "fixes" for XP before this happened? There have many reports of various system glitches after fixes have been downloaded. My sympathies to those with XP ... /w3tcompact/icons/wink.gif
DVerbarg,
Nope, none lately.
I haven't heard of any problems with any of the upgrades, but ya never know.... /w3tcompact/icons/eyes.gif
Terry
   / Computer CDROM Expertise... #10
A bad Mainboard is a possibility.
I've lost two, over the last several years. However, in both cases, the computer wouldn't boot at all.
2017 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2017 DRAGON...
2008 Jeep Wrangler Unlimited X SUV (A53117)
2008 Jeep Wrangler...
Honda UTV (A53117)
Honda UTV (A53117)
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
2019 VOLVO TRUCK VNL (A53843)
2019 VOLVO TRUCK...
2015 FORD F250 SUPER DUTY EXT. CAB (A53843)
2015 FORD F250...
