Compressor Oil
   / Compressor Oil #1
Magruder
Michigan
John Deere 790
I have an old Iron Man upright air compressor. I got it used and no owners manual. It is very low on oil and I don't know what the proper weight/viscosity is. Anyone know?
   / Compressor Oil #2
You can buy air compressor oil specifically in that section of the hardware store. I think that you could substitute regular motor oil and save some money, but if you aren't sure, just get the stuff that's intended for that use.
   / Compressor Oil #3
If proper compressor oil isn't available mineral oil should work.:)
   / Compressor Oil #4
Non-detergent SAE 30 weight is pretty much the standard oil for air compressors.Find it at your local auto parts store.
   / Compressor Oil #5
yep.. if no compressor on in stock.. then 30wnon det..
( lowes and tsc carry compressor oil for sure )
you CAN get synthetic compressor oil now as well.
   / Compressor Oil
Thanks for the info. everyone!
   / Compressor Oil #7
For a lot of years, I used 30W motor oil, but my current 6+ year old compressor's manual says "NOTE: The compressor is pre-filled with synthetic oil. We recommend using a good quality 10W-30 synthetic motor oil for this pump." So I use the Ingersoll-Rand All Season Select Lubricant. It ain't cheap, but I run my compressor a lot and sometimes continuously for long periods of time. And it hardly uses any at all between changes.
   / Compressor Oil #8
some new lawnmowers say the same... getting away from the old 30w dinosaur days.. :)
   / Compressor Oil #9
Since my little Toro ZTR has a Kohler engine, I'm using the Kohler 10W-30 oil. I asked my dealer who makes it and he said he didn't know. I'm curious, and of course, it's expensive oil, but to change once a year, I figure it's not bad. I don't think it's synthetic, but I can't say for sure. The manual does say, "Synthetic oils will provide better starting in extreme cold below -23C (-10F)." And no, I'm not kidding.:laughing: But I've never mowed my yard when the temperature was 10 below zero.:laughing: I couldn't believe that was in there.
   / Compressor Oil #10
i have a lil farm CUV thing like a golf cart. they reccomend 15w40 though say 30w is 'ok'
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2014 FREIGHTLINER M2106 BUCKET TRUCK (A51406)
2014 FREIGHTLINER...
JOHN DEERE 8R310 TRACTOR (A54756)
JOHN DEERE 8R310...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
