bcarwell
I'm in urgent need of an answer or educated guess for sizing a compressor for a pneumtic jackhammer on Craig' List.
All I can tell you about the jackhammer is it is 90 pounds, has a "rotary tip" function and uses "larger" hoses. The guy is calling back with the brand/model but in the meantime I thought maybe you could at least get me in the ballpark.
I need to know if I could get any use out of it with an obviously undersized 2HP running, 6HP max, 30 gallon, 8.6 cmf @40 psi, 6.4 cfm @ 90 psi compressor.
When I say "any" use, let me be clear. I am in Central Texas putting in about 15 fence posts on my property and go down 18 inches and occasionally hit limestone of varying size, thickness, such that my post hole digger doesn't go further. I am NOT concerned about being able to have a high duty cycle like professionals who break up highway concrete for a living. I just need it to pop the bottoms of these holes a few times and rest while the compressor builds back up and I clean out what it broke up, and then repeat, and hopefully allow the post hole digger bit to catch and get down another 6 - 12 inches. If it takes 1/2 hour per hole to get through this last 6 - 12 inches that's fine.
I don't think many other suggestions of alternates would be of much help as I've thought of/tried most. A Beltec hydraulic downpressure 3PH post hole digger is out of my price range- renting or buying. I've tried water to lube the hole which helps some, and a fishtale bit on my auger. I don't think weight on the PH digger would help either. There is an electric jackhammer for rent for about $100- half the price of this jackhammer which is 2 years old and priced at $200. The rented electric jackhammer is only 60 pounds and I bought and returned an electric jackhammer from Harbor Freight that was about the same weight because it didn't do much. I hired a guy to dig 20 or so holes in another location- too pricey and I doubt anybody'd even do 10 holes or so. I have a LOT of patience in digging these holes and just can't think of an alternative I haven't tried to a jackhammer (which people use around here use to put in sign posts- electric jackhammers but the signs are not intended for permanent installation unlike fence posts).
Bottom line is could I get even five or six useful pops from the jackhammer out of such an obviouly undersized compressor before it needed to recharge ? If so this pneumatic jackhammer would be useful, as I occasionally have the need for drilling only 5 or so post holes from time to time- not enough to justify renting or buying anything else. But it would be nice to have something around here permanently that could at least break this stuff up a little and to avoid the inconvenience and expense of repeatedly renting from time to time.
Sorry I don't have specs on the jackhammer yet. I just thought maybe somebody could guess what the absolute minimum compressor requirements for these boys, given the weight of 90 libs (which doesn't sound like a Godzilla type jack hammer).
Any info quickly would be much appreciated.
Bob
Bob
