Compression Valve
   / Compression Valve #1
chauke
Yanmar 1500
I recently bought a Yanmar 1500 tractor and have a question. Before I went to look at the tractor, I watched some Youtube videos to get familiar with some basic starting/operating a tractor. One of the videos showed someone using the compression valve when starting the tractor. When I went to check it out, the previous owner didn’t use a compression valve when he started soi I just assumed it didn’t have one. Later, I noticed the compression valve and asked about it. The previous owner didn’t even know it was there. It seeks like I should use this when I start it. However, I am concerned that if it has not been used for so long, would it be worse to try to use it now? My concern is that if it somehow failed when I was trying to use it and would be stuck in the “exhaust valve partially open position” that then I wouldn’t be able to even start it. Thoughts?
2014 Ford F-150 Pickup Truck (A50323)
2014 Ford F-150...
Scag Tiger Cub Zeroturn (RUNS) (A50774)
Scag Tiger Cub...
2010 Nissan Rogue SUV (A50324)
2010 Nissan Rogue...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2012 Crane Carrier Low Entry Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
