Compression tubing
/ Compression tubing #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I was not sure where to ask, if out of place, my apologies.
Anyway, messing with nice old Sears compressor and the part I have to replace is a piece of copper tubing 1/2" OD. So far I checked only Home Depot and they have nothing but I was able to find rings for the compression fittings there. Any idea where to look for the tubing? I need about 12".
/ Compression tubing #3
One type tube goes by ID and the other by OD. If it uses flared fittings, just flare it and use it. Adapt it to use flared fittings. You can get NPT to inverted flare adapters. I'm not sure what you are trying to accomplish. Natural gas and butane/propane use flare fittings and they fit JIC hydraulic fittings. I use hardware store fittings when I take hydraulics apart on logging equipment in the woods. Just to cap and plug things.
/ Compression tubing #4
Check a ACE hardware for 1/2 copper tubing.
I am trying to get the compressor running but this piece is bent and leaking and I have to replace it.
/ Compression tubing #6
There are different grades of copper tubing based in part on pressure. Type L is used for gas, but at very low pressure. Not sure what you might need for compressed air.
/ Compression tubing #7
1/2" od is a refrigerant size tube so any local AC company should stock, or Amazon sells short coils. "L" copper is fine for the application.
/ Compression tubing #9
Soft copper tubing is at alot of hardware stores or box stores like Lowes, home Depot, etc
More important question, do you have tubing benders to bend it without kinking it. Tubing that size and the 90 degree bend most compressors have coming off the head and going to the tank....benders are almost a must.
Another old truck that works is wrap it tightly with wire or solder. Then bend and it won't kink
/ Compression tubing #10
I’ve heard of filling the tube with sand but I’ve never tried to know if it works.
/ Compression tubing #11
I have the wound spring benders. Used one on 1/2" copper a couple of weeks ago and still kinked the tubing by trying to get it too tight. Looking in to one of the brake line type benders, but even those have a maximum radius.
/ Compression tubing #12
Can you cut it at the bent spot and use a compression union? Maybe drive a punch inside it and straighten the tubing enough to get the union on?
/ Compression tubing #13
Small quantities of tubing or rod are easiest to find online. If you have a caliper, you can order an exact match.
/ Compression tubing #15
I can say that for my compressor, the original tubing was hardened, not soft tubing. The original tubing got extremely warm, warm enough to have the copper change color. That makes me wonder about the longevity, and wisdom, of repairing the copper line rather than replacing it. FWIW: The copper line is available as a part for many compressors.
Personally, after fence sitting for a bit, I bought a name brand used die type tubing bender online as good ones were $$$ new. I didn't have much faith in my ability to get good angles using a spring bender for multiple sequential bends in 1/2"OD tubing. I wanted to build an intercooler for my compressor to reduce the amount of water going into the main tank. It works great, removing 95+% of the water, and some of the oil.
All the best,
Peter
Back in the day when we were building windsurfing gear we used sand to bend aluminum tubing, it worked reasonably well however the bend was very slight, more like an arch.
Anyway, got a piece of tubing from ebay and the compressor is running again. Love it. Two stage is so quiet. I added a ball valve and hooked it up to my air line system in the shop. Picture is not mine, found it on the internet.
Kubota L2501 (A62177)
Light plant Generac Magnum (NONE TITLED) (A63569)
Light plant...
2024 Blue Diamond Skid Steer Vibratory Roller (A63116)
2024 Blue Diamond...
6 1/4 INCH OD 90 DEGREE ELBOWS (A63569)
6 1/4 INCH OD 90...
iDrive TDS-2010H...
2020 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2020 DRAGON 150...
