Compression Testing
   / Compression Testing #1
rock2610D
Cheyenne WY
2610D
Can anyone tell me if this will work?
I have a compression tester that goes to 300 psi. I have been able to screw the end of the compression tester into the fuel intake port of one of my old injectors.
If I remove the needle in the old injector will that work? Or should I remove the entire middle section of the lower injector? Better yet is there any way this could work. I realize I could have way more than 300 psi but if you think this will work all I will have to do is purchase a 5 or 600 psi gauge.
   / Compression Testing #2
You can completely gut your injector and do it that way. We used to do it like that. Or you can buy one of our compression test adaptors for about $15 and not worry about damaging your injector if yours are still good. I think our kit has a gauge that goes to 1000psi.
Aaron
Parts@hoyeTractor.com
(940)592-0181
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A53473)
2020 Massey...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
1264 (A50490)
1264 (A50490)
30ft Highway Trailer Co. Lowboy (A53473)
30ft Highway...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
