Complex machine
   / Complex machine #1
n4msl
Weaverville, NC
Kioti DK40HST & MF 1020
I recently took delivery of a DK40SE-HST and am amazed at the complexity of this tractor. There are few direct mechanical connections like in my old MF 1020. Everything is operated by cables or electrical solenoids. This, to me, portends many future problems with corroded electrical contacts, switches, electronic boxes, etc and it seems that it would be a troubleshooting nightmare. If the dash display ever goes down I might be tempted to junk the whole tractor rather than try to figure what is wrong. Have I lost contact with modern tractors? Are all tractors this complex these days?
   / Complex machine #2
I bought my CK30hst six years ago and was also surprised at the apparent modern designing of the systems. But then I was updating from a 1948 Ford 8N. Times have changed just like with road vehicles. Luckily these tractors can still be worked on by anyone who has some mechanical ability or experience and the shop manual does help even though it's not like the Motor's, Chilton, or Hayes manuals. From what has been posted prior, a small computer for the engine is coming to deal with emision requirements.
   / Complex machine #3
I think if you keep the tractor under cover it should go a long way to keeping the electronics happy. The only really important electronic doo-dads are the glow plugs, 4wd engagement, and PTO engagement. I don't really worry about the rest. If push comes to shove I think wiring all 3 of these to simple switches on the dash isn't rocket science. Go get the service manual from the dealer, the wiring diagrams aren't all that scary and it gives you a trouble shooting guide.
My neighbor's $150k JD is a different beast, the amount of electronics on that kept a tech from the dealership busy for a couple days in the middle of hay season checking connections with cable bundles as thick as your arm running a few different places...
   / Complex machine #4
I have to agree with IndyIan. The electrics are pretty elementary; nothing like a current-vintage car. Assuming you can use a multimeter, the hardest part of electrical troubleshooting is physically locating the part of interest. Also, as other posts make clear, the "all mechanical" approach is not foolproof. The only electrical problem (so far) in my 2006 DK4S5 was accumulated dust/dirt in the ignition switch which produced intermittent starting (glow) problems. I can't speak to the HST models but I consider my machine to be pretty rugged, including the electrics, but my instrument panel is just idiot lights and tach.
   / Complex machine #5
n4msl Aw c'mon now. It isn't all that bad, have you checked into your rig lately? There have been some innovations there too in the last 20 years. Everything is more complex than it was. and while there is a microcontroller for the dash, It is no where near as complex as the average car. Sure I am hoping everything keeps on working correctly, and gives no problems too. Is it as simple as my dads 1949 Super A? No, but it does a heck of a lot more too!
73
James K0UA
   / Complex machine #6
N4 like the others are stating these units have simple switches and wireing so don't fret too much about it. That is one of the main reason I purchased my tractor. Modern cab and convienance with out the computers. Wait for a year or so when the emmissions crap comes out, then you will see problems and high fuel use. CJ
   / Complex machine #7
All tractors are built this way regardless of brand name. They're actually real simple with a few relays, switches and built in timers, etc. The parts are made to be replaced if defective, not repaired, which keeps cost down for initial purchase and consequent repair(s). Most household appliances have more electronics than a tractor, such as, dishwashers, refrigerators, washer/dryers, microwaves, etc. Its nothing to be concerned about.
Tier 4 emissions requirements will not cause high fuel consumption. It will however reduce particulate emissions as intended.
   / Complex machine #8
You aren't wrong; some people tend to get seduced by the bells and whistles, until they fail.
What I liked about my new Kioti was that it had the same basic design as my 30 year old Kubota. For me,the fewer solenoids and switches, the better.
   / Complex machine #9
Tier 4 emissions requirements will not cause high fuel consumption. It will however reduce particulate emissions as intended.[/QUOTE]
So far that has not proved true. The units that meet the spec either have to do it with urea or for the bigger stuff regen cats. OR they don't make enough USEABLE power to speak of. Units that run a set rpm have been ok but anything that varies rpm like well service rigs have been a joke. JMHO and experience. CJ
   / Complex machine #10
I thought we were/are discussing tractors?:confused2:
I can't comment on well service rigs, or other specialty rigs.
Is there documented proof of higher fuel consumption, or is that just anecdotal evidence?
2023 Spartan RT - HD Zero Turn Mower (A50514)
2023 Spartan RT -...
20' One Trip Shipping Container (A50514)
20' One Trip...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2007 Volvo VNL Truck Tractor (A52128)
2007 Volvo VNL...
