Competitor Cross Reference FYI
   / Competitor Cross Reference FYI #1
minidozer
CA
Dozer
I will be purchasing a WIX 33972 (5/16" inline 50 micron plastic mesh) diesel fuel filter for future use. Because some stores only carry Fram products, I did a Fram search and found they recommended a paper gas filter as a cross reference. Does cause one to question other product cross references.
   / Competitor Cross Reference FYI #2
50 micron is pretty large. Bugs will fly through it. 10 micron is better.
   / Competitor Cross Reference FYI #3
50 micron is for gasoline engines. Sorry.
Bob,
WIX 33002 ".....use only w/gasoline (not diesel) - for diesel fuel, use 33972"
I am currently using a 10 micron filter. Post bugs, I would like to go to a cheaper inline filter. Do you know of a 5/16" inline filter for diesel less than 50 microns? Auto Parts stores tell me if it does not state "for diesel" it is for gas. 50 microns seems a lot smaller than the screens provided by the manufacturer when the dozer was new. WIX never replied to my emails asking about inline 5/16" diesel filters.
Background - When new, dozer had screens in fuel tank discharge, top of sediment bowl and banjo fitting of the lift pump. To clean/change the fuel tank discharge screen, the sediment bowl assembly had to be removed therefore fuel tank had to be emptied. I removed all factory screens and the sediment bowl assembly then installed a ball valve on the fuel tank which fed a Racor 20 series unit with a 10 mircon filter (S2502) as a prefilter. The Racor unit was installed next to the removable panel opening for easy access. After bugs, I plan to change the 10 mircon filter to a 250 micron screen (S2501) followed by an inline diesel fuel filter.
2006 Ford F-150 XLT (A44501)
2006 Ford F-150...
2014 Ford E-150 Cargo Van (A44571)
2014 Ford E-150...
Pallet of Irrigation Hoses (A44502)
Pallet of...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A44391)
New/Unused 30ft x...
INOP/NON-RUNNING 1998 GMC W4500 Truck, VIN # J8DC4B1K3W7004717 (A44391)
INOP/NON-RUNNING...
YANMAR VIO27-5B (INOPERABLE) (A45333)
YANMAR VIO27-5B...
