3-Point Hitch Compatiblity
   / Compatiblity #1
Batavia,Ohio
John Deere 2720
I have a john deere 2720 which I installed Pat's on (really like them), now I want to add Hydraulink and would like to know if it will work ok since the Pat's extend the lift arms a bit. Any of you with this setup?
   / Compatiblity #2
:welcome:
The htl works well with the iMatch so would think it would work well with the Pat's too.
   / Compatiblity #3
I think they have extended screws for the hydraulink to work with quick hitches.
   / Compatiblity
Thanks for the replies, think I will go with the hydraulic top n tilt since the tractor has power beyond.
   / Compatiblity
I'd have to install a spool valve such as this thread: ( Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 ) in the hydraulic section of TractorByNet
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
UNUSED AGT NT18K EXCAVATOR (A51243)
UNUSED AGT NT18K...
2012 Ram 1500 Crew Cab Pickup Truck (A50323)
2012 Ram 1500 Crew...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
(8) 75 lb IH Suitcase Weights (A50515)
(8) 75 lb IH...
2008 Ford F350 Bucket Truck (A47384)
2008 Ford F350...
