Compatible Tractor fluids
   / Compatible Tractor fluids #1
Campo de Lorenzo
Baja Mexico
Ford 1984 545 A
I live in rural Baja, Mexico and I'm having a problem getting fluids for my 1984 Ford 545A tractor. The owner's manual only lists Ford 134 (transmission/loader) Ford 41 (power steering) and Ford 121 (engine crankcase). What compatible/standard fluids can I perhaps get here from a diesel truck supply? Thanks.
Lorenzo campolorenzo@hotmail.com Campo Lorenzo Home
   / Compatible Tractor fluids #2
Questions with Questions don't help you much, but this is the best I can offer.
Go to your local truck / tractor supply and look for something called a "universal tractor fluid" or something similar.
Sometimes they will be called UTF, TDH, THF etc.
Then flip the container over and usually (usually I said) they will have a chart or such on the back that says something like "meets specifications" and then will have a list. Look for the ford section, then look for the numbers 134, and then it will usually have a letter after it, currently they are on D, I think the vintage of your tractor it was C, so, C or D would be fine in my opinion.
If it does not have a data sheet on the container, sometimes you will need to run one down from the manufacturer or off their website.
To the best of my knowledge, most major oil suppliers produce a Universal type tractor fluid.
If it were mine, I would run the 134 fluid (whatever I decided met that spec) in the Powwer steering as well. SG will probably chime in here and may have some more insight, but most those things will at least work with the 134 then you have the same fluid.
As far as the engine oil, any diesel truck rated engine oil currently available should be fine. My personal preference is Rotella, but there are bunches out there and I would look for something of decent quality that I could repeatedly and easily buy.
If you have difficulties finding the specs on the products available to you, post the names and part #s readilly available too you and I can probably track down the spec sheets.
   / Compatible Tractor fluids #3
Can't speak for other fluids but I know that TRC's UTF fluids meet all the New Holland (Ford) ESN-M2C-134-A through -D and ESN-M2C-42-A fluid spec's. As far as the engine oil goes just pick your favorite diesel engine rated oil in the proper viscosity grade.
   / Compatible Tractor fluids #4
About any transmission / hydraulic fluid that is compatable with wet brakes would work. Straight hydraulic fluid won't work! You could also use that trans/hydraulic fluid or ATF in the power steering. 15w40 would be my choice in your temperatures for the engine oil.
Do you have a Walmart? they carry tractor fluid around here, might be worth calling to check.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A55218)
2023 NEW HOLLAND...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
