Comparison Advice for New Tractor
   / Comparison Advice for New Tractor #1
GKChesterton
Texas
CK2610 HST; B7800
Looking to get my first tractor. I've got a couple of acres in Texas, with the back acre covered in brush/saplings that I would like to clear and then keep in check with a rotary cutter. Will need something to move gravel for the drive, box blade some areas, and then also, help mow/manage sections of a deer lease and a private family cemetery (couple acres) a couple times a year. Size wise, I am hoping for a tractor that could work on both places, neither too large for my homestead nor too small to be of use on the larger pieces of land. I'd rather not have to upgrade later (and you never know when the wife might approve another purchase). Went to the deere and kubota dealers. They are the two dealers close enough (within a half hour) to be of use for any repairs later and both seemed like good guys with a long business history. Model wise, I liked the feel and what I read about the Kubota B2650 and Deere 2025R with loader, box blade, and rotary cutter. Both packages would be in the 20K range. The price is close enough that it wouldn't be the deciding factor, but I haven't really seen any comparison between these two models. Are they the comparable models of the two companies, or am I comparing limes to oranges? My feeling after seeing them in person was that the Deere was a little fancier but the Kubota was a little stouter, but does anyone have any experience that could help here? Would appreciate some help. The last time I used a tractor it was a ford 8n my dad and I restored in the late 90s and tractors have changed a lot since that one came out.
   / Comparison Advice for New Tractor #2
My advice is to not limit your search to those two brands.
   / Comparison Advice for New Tractor #3
   / Comparison Advice for New Tractor #4
Both good choices. Which one "feels" better and is the nicest to operate?
   / Comparison Advice for New Tractor #5
Love my deer 2520 which is essentially the older version of the 2025R. If you plan on doing lots of mowing maybe look at the higher horsepower models of the same frame such as the 2032 or 2038.
That's tough here. I looked at Branson and was impressed, but the dealer is over an hour away. Only other established dealer nearby is Case, but they didn't seem to have a model in my price range.
Thanks!
The Deere felt more comfortable, but I liked the function of the B2650. I'm leaning orange on this one.
   / Comparison Advice for New Tractor #9
Not exactly true. The 2320 was essentially the older version of the 2025R. The current 2017 and up 2025R is like a stretched out 1025R with bigger tires. Your 2520 would directly compare with a 2017 and up 2032R, but the new 2032R is like a shrunk down 3039R. At this time, Deere does not have a direct competitor for the Kabota B2650. On the other hand, the OROPS B3350 and 2032R should be quite compareable.
   / Comparison Advice for New Tractor #10
That’s true, I haven’t seen the frame size changes in person. I just know that when I am doing pto Work I could always use more power. Not that it is underpower, just wanting more so I don’t have to slow down in the thick stuff as much
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A52748)
2021 NEW HOLLAND...
2023 Evolution Classic 4 Pro 48V Golf Cart (A53002)
2023 Evolution...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
