comparing price and preformance
   / comparing price and preformance #1
oceaneering
Never owned a tractor, would like something to cut five acres, spread dirt or gravel, knock over small stumps, and push a bunch of cut trees around. How does Mahindra measure up to other tractors. Price, power, attatchments ect...
Thanks for your response
   / comparing price and preformance #2
Well, I'm sure everyone will have there own opinion but I personally think Mahindra Tractors offer the most "bang for your buck". Mahindra is a huge company that has been building tractors since the 60's. They are among the heaviest tractors in the class and offer a lot of standard features that are optional on some of the others. Price is going to depend on your local dealer but I think you will find that the prices are very competitive. Also, do some research on this site and I think you will be pleased with what you find.
   / comparing price and preformance #3
They are high quality and built heavy. The 20-32 HP units are built in Japan by Mitsubishi. You might consider the 3215, or if you are in a big hurry, step up to the 41 HP 4110. If you are really dealing with big trees and huge brush piles, go with a 5500 or 65004wd, but that would seem a little large.
   / comparing price and preformance #4
i think you would be happy with a 4110. i recommend getting the ag tires though if you are doing a lot of woods work. i have the industrial tires, and have to use tire chains when doing forestry work to get proper traction. i even had to get a set of front tire chains. as far as power and size go, the 4110 is just the right size for most applications. its not to big, and not to small. good lick with your decision!
   / comparing price and preformance #5
Also think about the 3525. It is a 35 hp tractor which can handle a front end loader, (FEL). Will pull a 6' bush hog. It will do the job well. It is a conventional tractor. Should cost in the range of $10,000 to $11,000. A 3525 list for $12,285.00 without the FEL. A 3525 is a remake of an International which Mahindra made for International back in the 60's. Good solid tractor. Doesn't have all the gagets which can go back. Just a solid tractor. Doesn't have 4wd. But I have been around and using tractors for nearly 50 years and never had a 4wd and never really saw I need one either.
Here are the specs.
Specifications
ENGINE
Type Four stroke, direct injection, water-cooled, diesel
Cylinders 3
Engine HP (kW) @ rpm 35.0 (26.0) @ 2300
Compression Ratio 19.4:1
Displacement cubic inch (cc) 115 (1891)
Cylinder Sleeve Wet replaceable
ELECTRICAL
Battery Capacity 12 volt, 96 amp hours
Alternator 12 volt, 36 amps
CLUTCH
Type Dual
TRANSMISSION
Type Sliding Mesh
Number of Speeds 8 forward, 2 reverse
STEERING
Type Hydrostatic power
BRAKES
Type Fully enclosed dry disc
HYDRAULIC SYSTEM
Type Independent, full-live hydraulic with draft and position controls
Pump Output (gallons per minute) 8.3
3-Point Linkage Category 1 & 2 adjustable with telescopic check chains
Lift Capacity (lbs.) 3525
Rear Auxiliary Remote Valves 1 spool optional
PTO
Type CRPTO (Constant running power take-off)
PTO RPM (engine rpm) 540 @ 2058
PTO HP (kW) 27.0 (20.0)
OPERATING WEIGHT
Total (lbs.) 4387
DIMENSIONS
Overall Length Inches (mm) 111.2 (2824)
Overall Width Inches (mm) 69.4 (1762)
Turning Radius Min. Feet (mts) 9.5 (2.9)
TIRES (SIZES AND OPTIONS)
Ag (Front / Rear) 6x16 / 12.4x28
Industrial (Front / Rear) 27x9.50-15 / 16.9-24
OPTIONS
Front Jerry Can Weights and Mounting Bracket Available
Just my thoughts.
Don
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
91013 (A48082)
91013 (A48082)
2000 INTERNATIONAL 4700 - 4X2 GARBAGE HAULER TRUCK (A51243)
2000 INTERNATIONAL...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2015 Jeep Compass Latitude SUV (A50324)
2015 Jeep Compass...
