Comparing JD 52 and 70 loaders.
   / Comparing JD 52 and 70 loaders. #1
ironwood
Pa.
Current: JD 955 70 loader,BH,MMM, JD755 52fel,mmm, (sold), 655 70fel.,mmm (sold), Ford 8N's w/ loaders x3 (all sold)
I have just sold my 755 wit ha 52 loader and before that unit I had a 655 with a 70 loader. I knew the 52 was harder to remove for mowing, and never really did it until just last week before I sold it. It was EASY, that surprised me, only slightly more hassle than the 70. That said, today I brought home my "new to me" 955 with a 70 loader. And the old familiar squeaks and sllight wobble made me realize my 52 loader was ROCK solid, no wiggle no sway, and WOW did I do a TON of earth moving with it (I moved 5000 ton last year). All last summer pavers and the City brought me concrete and asphalt chunk with gravel mixed in. I literally sorted several thousand ton with my little 755 and its custom made tooth bar. I put that thing to SERIOUS work. I also mowed with it and when my buddies JD skidloader ring gear was shot and he took it home I finished cutting inot my clay bank with the little 755 and a large off road forklift. I worked it hard, the only issue was at some point I stripped out the internally splined shaft that connects the motor to the tranny, so off it went to my buddies for a 10 month wait for him to fix it. We thought perhaps I collapsed the pinion bearing or cracked something in the casing, and thankfully that was not the case. He did it on barter for a $300 item I had and $300 in parts. This saved me like $3000 in JD shop time. So, I got it back and decided to upgrade. I currently have the 955 and it will be on lighter duty as I bought a Bobcat with Grouser tracks for the "heavy lifting". So in summation, the the 52 seems more solid than the 70. I like the 70 ALOT for my current work, but if I only had unit to use for dirt work (TLB or something) I would use the 52.
Ironwood
John Deere 8430 Track Tractor (A50514)
John Deere 8430...
UNUSED JCT QUICK ATTACH 84" GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2000 NEW HOLLAND LS180 WHEELED SKID STEER (A51242)
2000 NEW HOLLAND...
2025 GIYI Dual Cylinder Hydraulic Grapple Plate Bucket Skid Steer Attachment (A50322)
2025 GIYI Dual...
City of Lakeland (A51691)
City of Lakeland...
1999 Toyota Camry Sedan (A50324)
1999 Toyota Camry...
