Comparing Hydraulics?
   / Comparing Hydraulics? #1
Punk
Bronze Member
Tennessee
2006 Kubota M9000
When Mahindra compares hydraulics, between its 3535 and the Kubota 3240, they lead me to believe that the 3535 has more pump flow to the implement. Am I wrong when I assume the 3240 has more than the 3535?
The 3535 should only have about 6 gpm, for the implement, since it uses 5 of its 11 total for power steering. On the other hand, the 3240 lists more than 11 gpm total and 8.3 for the implement. Is Mahindra fudging the details, or am I missing something? Don't get me wrong, I'm not trying to knock the Mahindra tractor, I would like to know for sure before making a long trip to look at a Mahindra tractor.
Here's the comparison, on the Mahindra web site. MahindraUSA 35 Series
   / Comparing Hydraulics? #2
Punk,
The Mahindra 3535 uses 2 separate pumps the implement pump producing 11 GPM, and the power steering pump producing 5 GPM, totaling 16 GPM. Mahindra doesn't publish the added together figure as the others do, because it really has no value. The 5 GPM pump feeds only the powersteering, and the 11 GPM pump feeds only the hydraulic system. The 16 GPM total figure would sound nice and look good in the advertising, but has no real purpose.
g
   / Comparing Hydraulics? #3
You brought this up in a prior discussion and it was answered.
http://www.tractorbynet.com/forums/mahindra-buying-pricing/146652-4035-front-end-loader-bh.html
Thanks Galen, that helped alot. I guess I'll be taking that trip to a dealer. 11 gpm, for an implement, looks better than any Kubota, Kioti, or Bobcat that I've looked at; and I've looked at many that are much bigger in horse power and price. I've not looked at any that was over 10 gpm, for an implement, although I was up in the 50 to 55 hp range.
Thanks again
Thanks to you too, Buck.
   / Comparing Hydraulics? #6
Thanks again
My 2008 Mahindra 5525 (54 hp engine, 45 hp pto) specs out at 10.5 gpm at 2100 rpm engine speed for the main hydraulic pump and 4.8 gpm for the steering pump.
Looks like M&M goosed up the hydraulic specs for that little 35 hp (engine) 3535 compared to the much larger 5525.
Wish my 5525 could get 15-20 gpm out of the main hydraulics so I could use some of the neat skid steer attachments like hydraulic augers.
   / Comparing Hydraulics? #7
Implement Flow is good as long as you don't create heat and your resevoir is large enough to keep the oil cool. I am sure Mahindra took this into account. Are you going to use the tractor for a continuous flow operation like a hydraulic auger? Why do you need so much flow? The 3535 is basically a 40 hp tractor with a 35 hp engine. The 40 hp version is essentially middle of the road for specs all but the flow it has the most flow of any tractor its size that I know of.
   / Comparing Hydraulics? #8
What is the max travel speed of the 35 series mahindras?
That's what I was looking at. Using a Hydraulic post hole drill. The minimum for an auger is 10 gpm. I've seen tractors with much less, run one, but I'm looking for a small tractor with as much flow as I can get. I believe anything less than 10 would be a waste of money, as far as an auger is concerned. I hope 11 will do the job.
Thank you all for the imput.
   / Comparing Hydraulics? #10
If you want to run a hydraulic PHD on a compact tractor, don't buy one
that is intended for a skidsteer. I suggest the Worksaver 714H, which
works fine with 7GPM. I have used them on my backhoe.
Hydraulic specs from the different manufacturers are sometimes difficult
to find. Kudos to Mahindra for not promoting their "total hydraulic flow"
over the correct and separate PS and implement flows. Galen is totally
correct here. I have heard salesmen insist that the "total hyd flow" was
not just marketing. Of course it is. Kioti does not even publish their
implement flow specs, except in their service manual!
Anyway, the implement flow for the 3535 is excellent at 11 GPM, but it
is not really in the same class as the L3240, which is 1000 pounds less
tractor.
Kubota B7200 (A50120)
2016 Ford Explorer...
3 New 14in Premium Diamond Blades (A50322)
3 New 14in Premium...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2016 Ford Fusion S Sedan (A50324)
2016 Ford Fusion S...
