Comparable for Kioti 4510 HST Cab
   / Comparable for Kioti 4510 HST Cab #1
Sheepnanigans
Kioti NX 4510 hst cab
Shopping for a first tractor. Went and looked at Kioti a and liked the nx4510 hst cab over dk5310 hst cab. What other brands&models should I consider before taking one home? (No mahindra or TYM nearby).
For the same money (31.5 with FEL) should I stick with Kioti or get a smaller Deere or Massey? Or something else entirely?
Looking to care for a long gravel driveway (snow and reconditioning), move around round bales (the small kind, 700 lbs), till a garden (probably a 6 ft tiller), and play in the dirt.
thanks!!!
   / Comparable for Kioti 4510 HST Cab #2
Not sure if you have a dealer close by but if so you may want to go look at a yanmar YT347C. Very impressive tractor and basically the same size and power as the nx4510 you are looking at
   / Comparable for Kioti 4510 HST Cab #3
If you like the Kioti then get it. Great tractor.. That said, do make sure you look at other brands around you if you can. Couple days left to decide.
Bought the nx4519 hst cab. I did really like the Massey 2850M -really smooth FEL- but couldn’t justify the extra 10K. Unfortunately there isn’t a Yanmar dealer nearby, I looked for them but lo luck :(. Went to Deere - nothing on the lot and the 4044R that I liked on paper was a lot more $ (3046R was a couple K more than 4044R!). Midniteoyl, Why did you say a couple of days left?
   / Comparable for Kioti 4510 HST Cab #6
What other tractor brands and models should I consider?
NX4510 weighs 4,000 pounds bare tractor weight.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
   / Comparable for Kioti 4510 HST Cab #7
If you have a chance you just might wanna
check out this tractor:
10 year warranty
willy
This was definitely an option to consider. But no dealer with any stock any time in the foreseeable future near me.
   / Comparable for Kioti 4510 HST Cab #10
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2003 Lexus LS 430 Sedan (A50324)
2003 Lexus LS 430...
John Deere 250 Skidloader (RUNS) (A50774)
John Deere 250...
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
PT 500 Gal Water Tank (A50121)
PT 500 Gal Water...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
