I lurk this place pretty often, lots of info.
I joined to hopefully get some insight.
I am a residential contractor, exterior work. I do a lot of small tear outs, base prep, and need to move material often (crushed stone, sand etc.).
I need a new tractor for home use, and want to get something that I could also use for work when needed. I rent the equipment I need, but sometimes all I really need is a material mover for half a day, and it would save some hassle to just have my own machine parked there.
I currently have a B7100 that is a workhorse, but it's just not large enough for most things I need even though it puts up a **** of a fight.
I went and looked at the Mahindra 1526 in person, and it seems like about the perfect size (same machine as the 3016 from the best I can find). I would probably try to find a used 3016 HST with lower hours on it first, but what other tractors should I be looking at with similar size and lift capcities?
The Kubota L3200-3800 looks very close, although it seems like lift capacity is lower. I'm not opposed to more HP in the same size machine either, it's just really hard trying to sift through model numbers when shopping around. The ability to possibly add a purpose built backhoe (not a 3 point generic one) at some point would also be nice.
I'm really not brand specific though, anything about that size that has decent parts availability would work, used with low hours would be my first bet since it's a substantial savings usually, or at least comes with extra stuff.
I can't really swing a newer skidsteer right now, and if I could, it would still leave me without a tractor at home, so I'm pretty stuck on a tractor with a good strong loader.
Thanks for any help.
