Compact Tractor-Loader Specs Comparison
   / Compact Tractor-Loader Specs Comparison #1
Orahov
Ford 455
Hello, this spreadsheet compares the compact tractor published specs. Made this upon making up a purchase decision. Tell me what brands you think I should add, I know I'm missing JD, LS, & Mahindra. Bad Boy & Rural King should also be added.
Compact Tractor Specs
   / Compact Tractor-Loader Specs Comparison #2
You've put a lot of work into that document. I hope future buyers take advantage of your work.
   / Compact Tractor-Loader Specs Comparison #3
Need to add Yanmar too. Believe the YT235 lifts 1300lbs and the YT347/359 lift 2500lbs.
   / Compact Tractor-Loader Specs Comparison #4
Great chart! That should be a site sticky, if ever there were one.
As to what to add... I've always used loader lift capacity at 60" for comparison, instead of lift capacity at max height. My reasoning is that, when an object is very heavy, near max capacity, I'm never lifting it to max height. Where I usually need max lift capacity is when lifting logs off the ground with chain slings or forks, or when lifting pallets out of the back of a delivery truck. Both of these activities happen between 0" and 60" off the ground, never near max height.
   / Compact Tractor-Loader Specs Comparison #6
Id be curious if someone has the specs to build an excel spread sheet with the dimensions off the loaders and cylinders where you can plug in the hydraulic pressure, loader angle and calculate the max lifting force across the loaders movement range.
Then you would calculate the ballast requirements.
We do something similar to this at work all the time for our machines.
I would think most the machines run out of ballast before anything.
Thanks, in the future I will link a Youtube video I saw of someone else doing a similar chart (if I can find it again).
Thats very true to point out, however its hard finding specs consistently at 60", either at pins or certain distance away from bucket; across each brand/model. Especially with brands using metric/imperial measurements it gets extra complicated.
That would be very interesting to see. To add, you could take those tractor-loader dimensions and calculate the moment (tendency to rotate) that causes the tractor to tip over (on level ground).
   / Compact Tractor-Loader Specs Comparison #10
True. But there are two possible work-arounds:
1. Just use whatever closest "shoulder height" number is provided, whether that be 1.5 meters or 60 inches.
2. Do a simple linear fit between whatever numbers are provided. I can help with this, if you have data.
The table you have is already very good, even without this. My thought was just that choosing a loader which is engineered to show the best max lift at max height, at the expense of the 60" number, is not always in ones best interest.
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
2009 Ford F-150 Pickup Truck (A48081)
2009 Ford F-150...
2004 Toyota Camry Sedan (A48082)
2004 Toyota Camry...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
2008 Saturn VUE XE SUV (A50860)
2008 Saturn VUE XE...
