Compact Tractor Guide
   / Compact Tractor Guide #1
Annihilator26
Ann Arbor, MI
LS/XJ2025H
I finally got my beautiful, new, blue tractor :D, but I would say that I am extremely underwhelmed by the operator's manual that came with it :(. Is there a good guide somewhere for someone who is new to tractors? I am thinking something along the lines of a book or website with a chapter on "Using your Front End Loader", a section on hooking up 3-pt implements, some practical advice on running a rotary cutter for the fist time, etc...
This forum is incredible when someone has a detailed question, but a single guide would probably be much more useful for a lot of people. I tried a quick search, and while my googlefu is usually very good I couldn't come up with any good unified guides either in print or online. I know that most people probably learn their tractor skills on the job, or from their parents, but I am sure I am not the only person to just venture out, and buy 6 acres and an LS.
If there is a good resource out there please point me to it, otherwise I will put it together as I learn.
   / Compact Tractor Guide #3
I don't know about the LS manual but the Branson one actually had some useful operating information disguised as ignorable safety instructions, largely in pictures. It took me a couple times of reading through the manual before I noticed. No one writes text any more, among other reasons because it has to be translated.
   / Compact Tractor Guide #4
Ask Tractor Mike is awesome. Has taught me many of the basics.
I appreciate the recommendations from Steve and ericm. The videos from Tractor Mike are helpful, but I would really prefer something written instead of a long series of videos. I also looked at the Branson manual. I admit that it was better than the ones from LS and Kubota that I looked at first, but I would still prefer something a little more in depth.
In addition to a general tractor guide, a collection of model specific info would also be really helpful. I didn't find any grease fittings on my tractor other than the ones on the loader when I took my first walk around, and after checking my owners manual I now know that I should also put grease in fittings at "Front axel holder, 3-point linkage, etc". How much? "Proper amount". I know I will just add a little grease every few hours of use, but it would be really nice to get a diagram of all of grease fittings to make sure I am not missing any. The New Holland Boomer tractors are basically the same as mine, and the manuals are much better, so maybe I should just get a copy of one of those and work from that.
   / Compact Tractor Guide #6
The manual for my first tractor, a '90s Kubota B7100, was pretty good.
I'd forgotten about Tractor Mike. I watched a bunch of his videos when I was tractor shopping a year ago. I too would rather read but most people find videos easier to make than writing.
I pump the grease gun until something comes out somewhere. I'm still finding grease fittings on my Branson.
   / Compact Tractor Guide #7
check underneath ur tractor as well. U probably have some zerks for pedals and brake. As for operation of the fel. If you going into a pile of dirt there is no need to spine the tires and digging holes hoping to fill ur bucket. Two things happen. One is u don't get the bucket full and the other is when you come back to the pile its rough as ****. Ease into the pile and then lift up on the bucket and curl just a bit then uncurl a bit and curl again. Keep repeating until ur bucket is full. Shouldnt take much when doing it this way. This will keep you from spinning ur tires and digging holes. Also avoid heavy corner lifts or you can spring the loader. I typically don't try to fill the bucket. Tractors aren't loaders. 2/3rds full bucket is plenty.
   / Compact Tractor Guide #8
... Also avoid heavy corner lifts or you can spring the loader....
Can you (or someone) elaborate. I don't know what a 'corner lift' is (nor what would be a normal vs a heavy one). Don't know what 'springing a loader' means either.
I like your method of getting a full scoop without just trying to push into the pile with brute force and tear up the ground for your next trip. Coming from an 80HP backhoe that carried a yard at a time, getting used to same tractor as OP is very much different. I will say 2/3 full bucket on my machine.....may as well use a shovel and wheelbarrow :) Already feels like I'm moving a tablespoon at a time compared to what the old backhoe could move.
I agree that the LS manual is vague at best in some areas.
   / Compact Tractor Guide #9
Reason it out.
"Heavy corner lifts" means picking most of the weight on the corner of the bucket instead of centering your load.
"Spring the loader" means twisting the loader frame work.
   / Compact Tractor Guide #10
As a first time tractor owner for a little over a year, I’ve relied on this site, the manual and YouTube videos. I bet there are books out there, but haven’t searched yet. I feel pretty competent after a year. Only thing f’ing with me right now are my tire chains :)
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
(1) 24' CORRAL PANELS W/ (1) 8' GATE (A51243)
(1) 24' CORRAL...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
2006 DITCH WITCH RT40 RIDE ON TRENCHER (A51242)
2006 DITCH WITCH...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
