Compact? or sub-Compact-or mini Compact?
   / Compact? or sub-Compact-or mini Compact? #1
deepNdirt
Veteran Member
Nth East Ga, USA
yanmar YM-1700
For all the time I've owned this size tractor I have always considered it a "Compact Tractor" although the more I read about tractors and size of tractors I'm finding out that "Compact" can be up to 50-60hp tractors, and what I would have considered full size large tractors--> example -> What?s new in compact tractors from John Deere
if these size tractors are considered "Compacts" then what are our smaller 17-30 hp tractors really considered?
sub-compacts or perhaps mini compact tractors? and then what would actually be considered a full size or standard size tractor? I always considered the large AG tractors "Monster Tractors" but are they really thought of to be the standard tractor?
:cool: I guess my brain is confused once again :confused:
   / Compact? or sub-Compact-or mini Compact? #2
I guess in my simple thought process, I would not necessarily define a tractor as sub-compact or compact based on horse power, rather I would consider any tractor with a limited cat1 hitch as a sub-compact. Such as my BX23. It has cat1 size pins, but the geometry of the lift arms and top link has closer spacing to a cat0 hitch which can be found on larger size garden tractors.
   / Compact? or sub-Compact-or mini Compact? #3
IMO a tractor with a cat-0 3ph would be considered a sub-compact. I would classify my power king (14hp) with a cat-0 is a subcompact. A very capable tractor for what it was designed for. A tractor with a cat-1 would be considered a compact and start into the utility class. Class-2 and above I consider as utility or special purpose type. Also I believe it's based on purpose i.e. multipurpose, AG, Forestry, Construction etc.
   / Compact? or sub-Compact-or mini Compact? #4
The later BXs have a full Cat 1 hitch and horsepower up to 25.5. I would still have to consider them "sub-compacts".
The B2320 has 23 hp but I think Kubota calls it a compact.
It doesn't seem to be based on Hp or hitch style.
Maybe the classification is based on the size of the wheels. Maybe it's just totally arbitrary!
   / Compact? or sub-Compact-or mini Compact? #5
That sounds about right. The wheels and tires make all the difference.
   / Compact? or sub-Compact-or mini Compact? #6
What about tractor width ? Couldn't that be one of the criteria?
   / Compact? or sub-Compact-or mini Compact? #7
I always assumed that it was the engine height
I would have thought the size and HP of any given tractor would put it in a particular size category, and a compact tractor to me is just that!
(small and compact) the example I used of the JD 4020 doesn't look compact,
actually it does read "Large chassis" But then says "Compact" :rolleyes:
so! there is something that borderlines this tractor as being a Large but yet compact tractor, although to me there is nothing about a tractor with 5-6 ft rear tires with a 40+ hp engine compact.:cool:
2017 FREIGHTLINER 126 SLEEPER TRUCK (A50505)
2017 FREIGHTLINER...
6 Yard Commercial Dumpster (A49346)
6 Yard Commercial...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A49346)
2025 Kivel 42in...
DAEWOO GC255-2 FORKLIFT (A50854)
DAEWOO GC255-2...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A48081)
2017 Mack GU713...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
