Compact 4110 Lost Prime.......HELP PLEASE
   / Compact 4110 Lost Prime.......HELP PLEASE #1
OakHaven
Florida
John Deere 4110
Worker ran my 4110 JD out of fuel. Tractor won't start so I am guessing it lost prime. Can anyone please walk me through how to prime this model? Manual has no instruction. Layman's terms please....this girl is no tractor expert. :) Thanks!
   / Compact 4110 Lost Prime.......HELP PLEASE #2
:welcome:
Your tractor is set up to be self-priming, so should be no need to bleed it.
I'd suggest following the procedure in the manual for checking and cleaning the fuel filter and see if the tractor will then start. There will be some cranking time, but limit it to 20 seconds or so at a time. Should start unless there is some problem with bad fuel or slime in the fuel tank.
PS We are all laymen here so no need to worry. And just fire back with any questions.
   / Compact 4110 Lost Prime.......HELP PLEASE #3
I for one would like to hear the outcome of this so please take the time to reply with the solution. Knowledge is always useful. Good luck.
Well it turns out the run down fuel was not the problem after all. A gentleman made it out to look at it this evening and he found a loose wire. I am so glad I found my way to this site. Lots of great information and very helpful people. Thanks!
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52705)
2015 JOHN DEERE...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A55218)
2018 John Deere...
Pallet of Miscellaneous Mini Excavator Attachments (A52377)
Pallet of...
