I am pretty close to deciding on a
B7800 for my 6 acres and i have some pretty heavy work to do. For example, removing felled trees, cleaning up pasture, moving dirt from a hillside in prep for a rock wall, driveway work, field cutting, posthole digging, etc.
Sounds like the typical kinda stuff. I have about 16.5 acres here.
My question is what is the most common failure on these tractors and how much do typical repairs cost? I know this an open ended question but any ideas I can get are appreciated.
Good question ..... my failures have consisted of the following:
1. Bent lift linkage arm for the MMM (due to incorrect installation by the dealer - they failed to bend a cotter key to secure it and it came loose and got bent up when I unloaded it off the trailer first time home. They provided new parts and I replaced it.)
2. Broken left turn signal lens (I inadvertently bumped into it when I wasn't paying attention.)
3. The rubber floor mat has worn thru in one spot.
4. Both front tires (R4's) have slow leaks in them ...... think it's an issue with them sealing at the bead. It's annoying because I need to remember to recheck the pressure prior to any heavy loader work.
I am also concerned with having the steering rods on the front of the front axle exposed. Is there a way to add some sort of protection to this? Is it even required? Are there other common "weak points" I should know about.
I'd say it's likey a non-issue unless you are navigating thru a field of boulders or logs. The steering linkage sits above, or at the top, the axle - so your axle will likely contact something first. I've run in the woods with lots of debris (logs, stumps) on the ground and haven't had any problems thus far.
I know most people use these tractors as mowers first and other projects as secondary.
I wish I could get to that point, but at this point for me it's been pretty much the reverse.
I am just wondering if this tractor will hold up to some heavy tasks..
I've used my
B2910 (deluxe version of the 7800) to:
1. tear up and remove about 400' of 6 inch thick asphalt driveway.
2. excavate (remove) the topsoil for the new driveway (8" to 20" deep and 12' to 18' wide and about 600' long)
3. Spread all the gravel for the new drive (something on the order of 250 tons of No.2 and crusher run)
4. clear a 100' by 100' pad for the new polebarn. (One corner had to be excavated to a depth of 4' or better and the opposite corner had to be filled in as much or more. I also had to remove a couple of large boulders - these were heavier than the loader could lift - about 3.5' or 4' in diameter - so I chained them to the bucket and dragged them in reverse to get them to where I wanted them.)
5. remove (with the backhoe) probably in excess of 50 to 75 tree stumps ranging in size from a couple of inches to 24" in diamter.
6. trench (with the backhoe) and install about 500' of french drains.
I have probably moved something on the order of 750 cubic yards of earth using the loader alone (there's a pile of dirt up in the field that's 25' wide x 50' long by 7' high - and that's not all of it) And I used the loader and my 4' x 8' dump cart to move around 120,000 lbs of sheep manure from my neighbors manure pile to my garden (at least 30 trips of about 4000lbs each over a distance of 3000', round trip.)
All in addition to mowing around 4 or 5 acres of lawn.
I just finished the 600 hour service on the
B2910 this evening and it's running great. I would say that these are pretty solid machines - I know I've given mine a workout. I don't pamper it - but I try not to abuse it either. Cosmetically it's gots some minor scrapes, dings, and places where the paint needs touched up, but keeping it greased and the oil changed will go along way to making it (and your
B7800) last a long, long time.
