Commercial Briggs V-twin governor issue
   / Commercial Briggs V-twin governor issue #1
vmaxman
pittsburgh,pa
troy bilt pony
Got a 28HP commercial briggs in a Ferris zero turn.
It was leaking oil from the sump gasket. Got that all replaced.
On initial startup, the engine revved to the moon.
Shut it down quick, and proceeded to attempt to adjust the governer
I loosened the governor arm on the shaft so I could spin the shaft and adjust it all but, the shaft will not spin.
It spun fine on the bench before reinstalling the motor.
Did the governor scatter and now I need to pull the motor and open it up?
   / Commercial Briggs V-twin governor issue #2
The governor shaft when the engine is assembled doesn't turn more than about 1/16-1/8 of a turn. Move the throttle shaft on the carb and determine which direction the governor shaft turns when the throttle is moved from idle to full throttle. Then while holding the throttle at full throttle turn the shaft in the same direction as it rotated when going from idle to full throttle and then while holding the shaft steady tighten the retaining bolt snugly.
The governor blew up. Found anew one and adjusted it correctly. Got it cutting grass again.
   / Commercial Briggs V-twin governor issue #4
That is so sad. I hope there was no other damage done during the high revving moment.
That is a lot of work, but now you are an expert on disassembling and reassembling the Commercial Briggs V-twin
Richard
2014 COTTRELL CX-09LS2 AUTO HAULER (A51222)
2014 COTTRELL...
Allied 760 Loader (A50515)
Allied 760 Loader...
2022 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A51219)
2022 FREIGHTLINER...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
