Comer shaft cover bolts....
/ Comer shaft cover bolts.... #1
Buckgnarly
Platinum Member
West topsham VT
Kioti DS3510
Anyone have an online source for those little T bolts that hold the shaft cover tube to the outer ends? I broke one removing the cover and no JD or Kabota dealers around here have them nor can get them. Seems like every other shaft uses the turn and remove as opposed to those stupid little plastic T bolts.
By "T bolts" I mean the clips that you turn 90 degrees to lock in place, 3 on each end.
/ Comer shaft cover bolts.... #2
You might try Woods Equipment. Their customer service is really helpful. I called them with a problem, and they were very helpful. I would check with them.
Good luck and let us know what you find out.
/ Comer shaft cover bolts.... #3
Might try a Bush Hog dealer. My Bush Hog 297 cutter has a Comer brand PTO shaft with the T bolts. My parts drawing list them as Part Number 87992 .
Six (6) required.
2020 Pitts Chip Trailer P16316 (A62613)
2020 Pitts Chip...
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2013 Chevrolet  Express 2500 (A62613)
2013 Chevrolet...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
2015 Ford F-550 Utility/ Plumbing Truck, VIN # 1FDUF5GYXFED42880 (A65563)
2015 Ford F-550...
