Color code chart for ignition switch.
   / Color code chart for ignition switch. #1
Moosehead.
Mitsubishi D2500 tractor.
Looking for a color code chart to wire up the ignition switch on a Mitsubishi D2500 tractor.
   / Color code chart for ignition switch. #2
I replaced the ignition switch on my D2350. I don't recall it having a color code. There were small letters by the terminals. One wire coming in is always hot. Use your voltmeter to find it. You can then touch it to each of the other wires to see what happens - glow plugs, starter, etc. You can use your ohmmeter to identify what terminals on your switch connect for the different positions. If using an automotive type ignition switch to replace the tractor switch do NOT use the ACC position for the glow plugs!! It is hot whenever the switch is on.
5' S/A CART (A52706)
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
JOHN DEERE BACKHOE FORK ATTACHMENT (A53843)
JOHN DEERE BACKHOE...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
