Cold weather starting and running help please!
   / Cold weather starting and running help please! #1
Mark_G
Va
Kioti CK30 Synchro Shuttle
This is my first Fall and winter as a tractor owner, and today was the first time I ever had trouble starting my CK30. It was 35 f or so out, and I let the glow plug light turn off before I started to crank. Lots of white smoke but it wouldn't catch. After several attempts it started to try to catch for a bit and then it finally fired up.
I have a few questions:rolleyes::
- How long should I let it crank if it doesn't catch? Should I try for some length of time (say 10 seconds etc) then let it rest a few seconds and try again? I don't want to over tax the starter etc....
- What can I do to help it start? Any particularly good block heaters etc? I'm sure it will be much colder here in the future.
- How long should it idol when it does fire to warm up? Just the standard 5 minutes?
- should I increase the engine RPM to help it warm up or keep it at low idol?
- Is it OK to drive it if the temp gauge doesn't show a temperature reading after the 5 min warm up time, if there is little or no additional load?
- how warm does it need to be to plow, as its only a matter of time....
Thanks all!
Mark
   / Cold weather starting and running help please! #2
In theory, at 35 F, you should not need more than one glowlug cycle to get her to fire up.
My LK3054XS will fire, in that temp after 1 to 1.5 minutes application of glow plugs.
With that said, when starting my dozer, in below freezing weather, and she has no glow plugs, I'll crank for 5 to 10 seconds and stop, crank for 5 to 10 seconds and stop and do this as I warm the cyls. and after 5 to 10 tries, she'll fire, blow out some white smoke, clear and run smooth. I see no need to crank the weee out of the starter. And I never, never, never use starter fluid on my diesel machines.
I am installing a water heater in my lower radiator hose, I've been told plug her in an hour or two prior to start and she'll start like it's summer. I also like the idea of warm fluids rather than cold fluids at start up.
Hopefully some folks with your machine will chime in.
On my little Kubota, I used to use almost full throttle at cold start, not sure how much throttle you used?
On my Kioti, I use low throtle when starting in any temp, same on the dozer.
I use the 5 minute warm up rule, typically to get my hydraulic fluid warmed up.
Sorry I could not be of more help.
   / Cold weather starting and running help please! #3
Mark
most importantly, make sure you have some anti-gel additive mixed in your fuel. even if your gas station has the winter mix, i still add a fairly strong shot of additive to the fuel. the additive also helps with horsepower and lubrication. i had a big problem during my first winter with the tractor.... i didn't use the additivie and the fuel gelled in the tank, filter and lines... of course it been several days of temps at near zero and below. live and learn...
my machine is kept in an unheated garage, so in winter i usually cycle the glow plugs two times and then engage the starter. when it catches, i hold the key a little to keep the glow plug light on for a few more seconds until the engine starts to smooth out..... it will take a little practice, but you will work out a plan that works for your machine.... good luck.
   / Cold weather starting and running help please! #4
I did the same on my Kubota, as soon as she caught, I'd flip the glow plugs back on. Made a huge difference. I had forgotten about that.
Good point on the additive, I did not add last year and never had a problem, but I will to be sure I'm safe.
Joel
   / Cold weather starting and running help please! #5
I start mine by giving it just a little throttle (getting pretty good at knowing where 1500 rpms is on the throttle arm), and wait on the glow plug light to go out. Usually starts right up on first try. I wouldn't grind too much on the starter (5 - 10 seconds at most). Cycling the glow plugs twice is a good idea if you are having trouble with the one-cycle approach.
When it's real cold (below 40), I always let mine warm up, initially at 1500 rpms, until the temperature gauge gets close to center before putting a load on her. This can take up to 10 minutes or more if it's really cold. About half way through this time I'll start exercising the loader (no load) to help get the hydraulic fluid warming faster. In warmer weather, I may drive it after only about a minute or so, but I still wait before putting a load on her.
I also keep mine on a battery tender all winter. I find this helps extend battery life by a couple of years and you are assured that the battery is ready when you are.
I haven't used the antigel agents yet. Probably gonna burn me one of these days. I do, however, keep the tank full to reduce the chances of condensation in the tank, and I buy from a place that sells lots of diesel so it's always fresh.
   / Cold weather starting and running help please! #6
My 3054xs has been a "hard cold start" from the get go. The lower hose heater is, essentially, a must. That being said, between the heater, a little throttle, and glow plugs, I can get it started without the old shake and misfire. I also flip the plugs back on after it fires and hold them for a couple seconds;really makes a difference
   / Cold weather starting and running help please! #7
My CK30 either starts instantly... or no amount of cranking is going to start it. I cycle the glow plugs once, crank for 5 seconds, if not running... repeat. Throttle is typically set to idle for starting at all times. Even down to 0dF, I have not had to do this more than 3 times. Below 0dF... I am not going out to try to start it!!
   / Cold weather starting and running help please! #8
Mark
I did the exact same thing on my CK20S last night. It seemed to work pretty well. Puffed some white smoke, rattled for a few seconds and then smoothed out. Temp was probably around 30F, maybe a little less.
Thanks all for the advise. How do you keep the glow plugs on? On my CK30 the plugs light illuminates at the key position just before ignition. I don't see how to keep the glow plugs heated while its starting/running.
Thanks,
Mark
   / Cold weather starting and running help please! #10
Just after engaging the starter can you flip back to glowplug?
Would not think that would cut your fuel flow.
Joel
2002 Ford Ranger Ext. Cab Pickup Truck (A50323)
2002 Ford Ranger...
2023 Polaris Sportsman 570 AWD ATV (A50324)
2023 Polaris...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2020 Case CX245D SR Excavator (RIDE AND DRIVE) (A50774)
2020 Case CX245D...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
