Cold Weather running bx-24
   / Cold Weather running bx-24 #1
whatever1
Earth
Any ideas ????
Kubota bx-24
Ran fine for about 4 driveways then it runs very rough barely made it back.
I have been using a fuel additive already and just added more even some of the stuff in the red bottle that you use after things gel.
Temp gauge read a little lower than normal when running. Here it is about 3 degrees.
Thank You in advance.
   / Cold Weather running bx-24 #2
You probably need to swap out the fuel filters. The back one more likely needs it than the front one. I had it happen on my BX twice with the factory filters. I added a Racor filter to mine and had it happen last year also, but at least it was easier to change. Don't forget there is two factory filters, one near the back underneath and one up near the injector pump near the engine. When my gelled up last year, I had also added an additive to my fuel. With the Racor I could at least see inside the fuel bowl and see the problem, it almost looked like white hand lotion in there.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
Lone Star dump trailer (A55973)
Lone Star dump...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
