cold weather hyd fluid
   / cold weather hyd fluid #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
Need some advice for cold weather fluids,my 336 works great but takes a long time to warm up enough to operate the loader, recent service w filter and screen clean,good fluid just not sure if theres an option for cold weather ? Thoughts ?
   / cold weather hyd fluid #2
they do make cold weather hydraulic fluids. I use Shell Tellus S2V22 i my hydraulic snowblower tank. They make a synthetic version also.
However , it might me way cheaper and easier to add a stick on electric heater to the tractors main hydraulic storage area if you know where on your tractor it is. I added a Wolverine Heaters - The Most Trusted Engine Oil Heater For Cold-Weather Starts style heater to my tank, made all the difference in the world. 1-2 hours heating and i was always good to go.
   / cold weather hyd fluid #3
Deere Low Vis Hygard. Mobilfluid 424.
   / cold weather hyd fluid #4
Quite a few use transmission fluid in cold climates. Tractor Ernie, a former dealer recommended it and his opinion is to be trusted.
53ft refer trailer (A51694)
53ft refer trailer...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
JOHN DEERE 2038R LOT NUMBER 175 (A53084)
JOHN DEERE 2038R...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
