Cold Starting problem B7300
   / Cold Starting problem B7300 #1
gbpf57
wisconsin
kubota B7300
Recently my B7300 starts very hard when cold. I give it 4-8 seconds of glow plug before starting, but to no avail. Is there a easy way to check for bad glow plugs ? What else should I look for ? Thanks, Tim
   / Cold Starting problem B7300 #3
I count to 20 when it's below zero, admittedly a different tractor but you might try longer.
I have owned this tractor several years and never had these starting issues using my current technique. Something has changed ??
   / Cold Starting problem B7300 #5
Try a search for glow plug problems. Fairly recently someone had a hard starting issue and discovered that not all of the plugs were glowing.
If you can find the post, he explained how he diagnosed the problem with a meter.
   / Cold Starting problem B7300 #6
A good glow plug should test about 1 Ohm when cold. 0 Ohms is a dead short, infinite Ohm is an open.
   / Cold Starting problem B7300 #7
Not sure what new glo plugs cost but you can get a very good magnetic block heater at tractor supply for $50. Just an idea.
   / Cold Starting problem B7300 #8
If this is a sudden change I would bet it is a glow plug problem. Very simple to diagnose.:)
   / Cold Starting problem B7300 #9
It sure sounds like a glow plug problem;
is the preheat circuit part of the starter switch fusing?
Case-IH 280 Magnum (A50120)
Case-IH 280 Magnum...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
J & M 30' Head Cart (A50514)
J & M 30' Head...
TRUCK FLATBED (A52472)
KJ 12'x20' Single Garage Metal Shed (A50121)
KJ 12'x20' Single...
