Cold Starting B6000E
   / Cold Starting B6000E #1
SteveM
Upstate NY
Kubota B7100DT
This is the first winter for me and my B6000E, and so far it has started reasonably well in the mid 20s with LONG glow plug times. My machine has a compression release knob, and I am looking for advise on how best to use it. Should I pull it out while cranking, and push it in just before she catches? Or leave it open as it fires up....
Dont want to do any damage to the little antique :)
   / Cold Starting B6000E #2
It fires with it out? I don't think so, or at least I don't think it should.
I believe the way you're supposed to use it is to pull it out and turn the engine over. Keep turning until the engine stops picking up speed and then push it in.
My B5100E's battery wasn't very strong and I found it to be quite a chore to get the thing started in winter. Mine was a 3 step process:
1) heat the glow plugs for about a minute (as per instructions on the dash).
2) Let the key go back to "rest" for 20 seconds.
3) Heat the glow plugs again briefly, like 5 seconds and then try to start it.
If I failed on the first attempt, that meant booster cables and my pick-up truck/w3tcompact/icons/hmm.gif.
   / Cold Starting B6000E #3
<font color=blue>I believe the way you're supposed to use it is to pull it out and turn the engine over. Keep turning until the engine stops picking up speed and then push it in. </font color=blue>
What he said..........
2010 Dodge Grand Caravan (A50324)
2010 Dodge Grand...
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
Adams 8 Ton Weigh Hopper (A52128)
Adams 8 Ton Weigh...
1999 Toyota Camry Sedan (A50324)
1999 Toyota Camry...
2011 Jeep Cherokee Laredo SUV (A50324)
2011 Jeep Cherokee...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
