Cold Start Problem Recommendation
   / Cold Start Problem Recommendation #1
ritcheyvs
Veteran Member
Kittrell, NC
Kioti DK45S
With the cold weather I notice a rash of cold-start problems on this site, many of which turn out to be the ignition switch. I had this problem and it was caused was dirty contacts inside the ignition switch:
http://www.tractorbynet.com/forums/kioti-owning-operating/225268-dk45s-hard-start-fixed.html
If this happens to you I'd recommend you first test the glow circuit by connecting a volt meter or 12v test light between chassis ground (or battery negative) and the common rail that connects the glow plugs. Then verify that you have voltage when you first turn the switch to glow AND also while you crank the engine with the starter. If the voltage goes to zero when you crank, you have a bad switch.
Replacing the switch is an easy, do-it-yourself job, maybe 10-60 minutes depending on your experience level and how far you have to walk to get your tools. As others (and I) have said, you can rebuild (disassemble, clean, lube, reassemble) the switch. But the switch contains springs and small parts so there is a real chance you will lose or break a critical part. I think new switches are about $50 and they may be a newer (improved?) design. If I were to do this again, I'd have a known good spare switch on hand before starting the job, just in case.
   / Cold Start Problem Recommendation #2
Good post!:thumbsup:
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
STORAGE FEES (A53426)
2015 GALYEAN 180 BBL STEEL VACUUM TRAILER (A52472)
2015 GALYEAN 180...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
John Deere 8400R MFWD Tractor (A53342)
John Deere 8400R...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
