cold hydraulics ?
   / cold hydraulics ? #1
GrayBeard
Pa.
First I'll say I've got little experience with hydrostatic drives.
I've got a Cub 7264 and in very cold temps. (below 30) the hydraulic system really "squeels" when first started.
After warm up it quiets considerably.
Would this be "normal" with hydro's ?
I can will/ post on the CC forum but wanted a "global" opinion.
Thanks,
GrayBeard
   / cold hydraulics ? #2
Hi. When the temps are below freezing, I usually start mine, set all the brakes, lower the FEL bucket into the ground (with snowplow in winter), and let it run at a high idle (in my case about 1/3 throttle) for about 5 minutes or so. In that short amount of time, the hydraulics usually warm up considerably. I use that time to shovel the porch steps and the small stuff that the tractor is too large for. Then I hop on, mash the throttle and plow away with no squealing. /forums/images/graemlins/tongue.gif
   / cold hydraulics ? #3
Good idea. My loader is really slow until the system warms up. It is good practice to let diesels run for a couple of minutes before you move them. The manual says something about maintaining the temperature during cold weather. You should keep the throttle around 1500 RPMs to keep it warm.
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A50324)
2008 Nautica...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
