Cold day at the Beach
   / Cold day at the Beach #1
JD-Beach
Virginia Beach
PT 425
Although a little cold, it's always a good day at the Beach! All the brothers-in-law were in for Thanksgiving and we spent the morning on the beach working on our annual sand-fence project.
Our best to you and yours for a safe and happy Thanksgiving!
JD
   / Cold day at the Beach #2
Great pics!
Glad to see family working together.
JD, how new is that PT? Does not look like it has been used at all.
Just a year old next month. Less than 50 hours use. I try to keep it clean, although, sometimes it gets a little sandy. Thanks.
   / Cold day at the Beach #4
I'll bet you are the envy of the beach! :) Happy Thanksgiving (a day late).
   / Cold day at the Beach #5
How about a little more detail about the fence. Why do you do it every year? I would think it is to stop blowing sand, is that right? Does it get in the way of all of the summer fun? I have put up a lot of snow fence and was surprised to see it looked like you use nails. I could be wrong. We use a pre-made wire tie that has loops on the ends then use a tool to tighten it up. If you are not putting it up permanently it is easier than nails and is also easier to fix if the fence is blown over.
   / Cold day at the Beach #6
I assume that this is to trap sand, getting the wind to drop its sand load at the fence? So this will help to build up the beach over the winter?
I'll bet you don't need a mower deck around there.
Do you do anything on the PT to resist salt corrosion?
John
Yes, Sawdust, the sand fence slows the wind velocity which causes the sand to drop on the leeward side of the fence. This builds up the dune through the winter. However, we often get a nasty "noreaster" that pushes the tide up and then the wave action takes the fence away. ... Resulting in the need to replace the fence almost yearly. We use hammer driven staples to fasten the fence to the posts. The tie wires that you mentioned, 3238dpw, sound like a good idea, I'll look into that for next winter, thanks. We just had the beach replenished this summer, so, it's unlikely that the tide will destroy the fence this winter. The replenishment comes every four years or so. We pay a higher property tax every year in order to pay for most of the replenishment, so please don't feel that your tax dollars are picking up the whole tab. I had to sign a city easement which allows the public access to the beach at my place in order to get the replenishment. The sand fence also serves to separate the "public" area of the beach from the private area, ... although we technically own and pay tax on the whole beach, we can't simply "claim" it for our own use. Beaches are like roadways and public utility systems, they need attention and maintenance. Please come and enjoy Virginia Beach.
Sawdust, you're right, no need for a mower here. As for the salt air, I keep the PT inside of a garage and try to keep it clean and dry. No indication of rust yet. I'm sure if it were left outside for an extended time the rust would show up.
(INOP) FORD 8N / 9N TRACTOR (A51247)
(INOP) FORD 8N /...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2018 Kubota M5-111 (A50123)
2018 Kubota M5-111...
Two Post Car Lift (A50120)
Two Post Car Lift...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
