Mowing CMS 60 blade problem
   / CMS 60 blade problem #1
expedoman55
Bronze Member
Hey Guys looking for some help. My tz22da has a Cms 60 has 3 high lift blades that I swap in the spring and then mid summer to ensure the blades are sharp.. Since I changed blades in the spring my blades seem to spin free on the hubs as if I cannot get enough tension on the blade to tighten it.. I am thinking the convex crush washers permanently crushed. Do any of you have any experience with this problem? I looked at new washers at NH and they are like 45. a piece x 2 each blade .. I don't mind spending the bucks but I am nto sure if that if that is the fix.
Any help is appreciated.
   / CMS 60 blade problem #2
You may need the hardened shim washers (P/N 36622) that are sometimes required with the hi lift blades. The hi lift blades are thinner than the standard blades....
   / CMS 60 blade problem #3
I just had to change my cup washers on my 54CMS as the blade was spinning on its own. I also changed the blade as the washers had worn a gouge into the surface of the blade. It all seemed to work.
LG 60" PIN ON WHEEL LOADER FORKS (A51242)
LG 60" PIN ON...
71055 (A49346)
71055 (A49346)
16ft Trailer T/A Equipment Trailer (A50322)
16ft Trailer T/A...
1240 (A50490)
1240 (A50490)
2022 Chevrolet Tahoe FL SUV (A50324)
2022 Chevrolet...
H & S High Capacity Hayrake (A50515)
H & S High...
