Clutch
   / Clutch #1
rovermac
Massey Ferguson 290
Hi, I recently bought a MF 290. In high range I cannot shift gears. I need to turn off the motor, shift, then start up. In low range shifting is possible but at times the gears grind. Any idea what is happening?
   / Clutch #2
Perhaps your clutch is not disengaging entirely. It could be a linkage adjustment issue. When the gears grind, do you have an implement such as a mower blade still spinning the PTO, which will cause the grinding problem. Lastly, the synchros or shift dogs in the transmission could be worn. Is the transmission full of the proper fluid ?
   / Clutch
The PTO turns even when disengaged, when I am in1st gear. It is now attached to a snow blower. However, if I start up the tractor in 3rd gear it does not spin when disengaged.
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2011 Jeep Wrangler (A51694)
2011 Jeep Wrangler...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
JOHN DEERE 5075GN LOT IDENTIFIER 115 (A53084)
JOHN DEERE 5075GN...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
