Clutch won't engage on my MT160D
   / Clutch won't engage on my MT160D #1
PDX
Mitsubishi MT 160D and Scott's L2548
Hi Guys,
I've poked around through the many threads and don't know if I have a stuck clutch or somethings else.
I have it blocked now as I read a note from Soundguy. I'll leave that way for a few days.
I had removed the bolt to the bottom of the clutch assembly and had forgot to replace so it was open all winter. Since I live in Oregon I'm assuming it allowed moisture in. (dumb move, I know).
I have other issues with this tractor but didn't know if I should post them all here or start a new thread? Input appreciated.
unstuck the clutch. Combination of mower attached and placing it in 2nd gear vs 1st gear on the PTO.
What is the recommended gear to run your mower? 1st or 2nd on the PTO?
   / Clutch won't engage on my MT160D #3
You should run the attacment at the rated speed. My mower is a 540 rpm. On my mt372 that is the "1" position on the pto....and welcome to the forum.
Thanks. I'll have to dig up the info on my mower, I'm not sure what the rated speed is.
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
Mobile Transformer and Power Substation Portable Power Supply (A55218)
Mobile Transformer...
1982 LeeBoy Motor Grader (A55218)
1982 LeeBoy Motor...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2020 Kinze 3505 High Speed 6/11 Planter (A55302)
2020 Kinze 3505...
