clutch warp?
   / clutch warp? #1
dickr
SOWEST, MONTANA
Kioti lb1914
I have a Kioti LB1914 w/ 666hrs. When I drove it out of the barn last week I got a grinding sound and when I depress the clutch while moving it stops like I put the brakes on. It has gotten worse as I drive it. (not driving anymore) I forgot to put a block under the clutch pedal when I parked it 4 or 5 mos. ago. could that be the cause of my problem and do I need to replace the clutch or just a pedal adjustment? (I hope) Any help is greatly appreciated.
Dick R SW Mt.
   / clutch warp? #2
If you shift to Neutral (try neutral in HI LO, F/R and gear range) does it roll? If not, the brakes may be draging, or a bearing may be binding, I don't think the clutch will stop the tractor. If the disk is frozen to the pressure plate or flywheel. you will just grind if you try to put in gear, and if you step on the clutch, the tractor will want to keep going, not stop.
   / clutch warp?
Thanx I checked the brake that's not the problem. I've found that the trouble is only in 4 whl drive. It moves along fine in 2 whl. When I drive in 4 whl, like in 3rd hi range (never use low range) maybe 6/7 miles pr hr and put the clutch in to coast it feels like I stepped on the brake very firmly.
Appreciate your time
dickr
   / clutch warp? #5
When you depress the clutch pedal does the tractor come to a stop or does it just seem like you are pressing firmly on the brake?
Does it seem to be one side or the other? Are any linkage rods bent or damaged? Have you checked all fluids?
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
2012 International 4300 Reefer Truck (A52748)
2012 International...
2008 Nissan Sentra Passenger Car (A51694)
2008 Nissan Sentra...
27031 (A51692)
27031 (A51692)
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
