Clutch shot on Grillo 107 D?
   / Clutch shot on Grillo 107 D? #1
Commonground
Can you help?
It seems that I shot the clutch on my Grillo 107D. I had the Bio100 chipper on, there was a jam and I tried to force it to turn. I did not smell much but the clutch doesn't work anymore. I had to pull the machine and chipper back to the barn by hand.
Where do I start? Is there a repair instruction manual somewhere?
Thierry in NS
   / Clutch shot on Grillo 107 D? #2
Hi! First! Try to adjust cable to lever clutch. must to have some loose as 3/8 in. Good luck! Oldmech
Merci,
j'ai telephone a Joel qui m'a dit la meme chose. Ca marche mais je crois que j'ai brule une partie de l'embrayage et je ne sais pas combien de temps il va encore durer.
(essaye d'utiliser les accents mais c'est illisible)
Thierry
   / Clutch shot on Grillo 107 D? #4
Merci,
Thierry
Wow! And here I thought I alway had the most typos on the board! :D
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2005 FORD F-650 (A52472)
2005 FORD F-650...
Kubota SVL95-2 High Flow Cab Skid Steer (A52748)
Kubota SVL95-2...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
