Clutch safety switch
/ Clutch safety switch #1
almaryholm
Bronze Member
Lake City,MN
TYM T450 w/ loader...had NH TC30
Maybe asked this before but still having trouble starting tractor at times... just get a single click when turning key to start...sometimes 3-5 times before tractor will start. Ya I have tried new solenoid / bench tests 3 times/ clean/ replace cables. ( think it might be safety switch on clutch, but I cannot find that .... switch) (( located inside dash ???)) Tractor is 2008 TYM T450
/ Clutch safety switch #2
Your best bet is to follow all the linkages for the clutch pedal. The switch has to be somewhere in that linkage.
I believe that tractor has suspended pedals, so the switch will most likely be under the dashboard, where the pivot shaft for the pedal is located.
/ Clutch safety switch #3
If you hear a click every time you turn the key that means all safeties have been satisfied. I would begin by making sure the battery is up to snuff and charged. Remove the cables and thoroughly clean the terminal and the cable connector. Inspect the connector end of the cables for signs of corrosion. Replace cables, tightening securely. If you can move them they're not tight. Now do the same thing at the chassis grounding end of the cable.
/ Clutch safety switch #4
What ptsg says! My 273 has a brake switch under the tractor and attached just above the brake pedal linkage. You clutch may have a similar attachment.
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2022 John Deere R4023 (A60462)
2022 John Deere...
2007 MACK CHN613 DAY CAB (A59905)
2007 MACK CHN613...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A59230)
2012 Ford F-550...
