Clutch replacement Jinma 284 ... any info appreciated "How To" video or instruction
   / Clutch replacement Jinma 284 ... any info appreciated "How To" video or instruction #1
kryptzard
Coventry, CT
Jinma 284 2002 Y385
Well, my tractor needs a clutch, it has just gone passed the point of adjustments... I have a mechanic to do the work, I am looking for any videos or information that might make the job easier. He is splitting the tractor in half to do it. Its a 2002 Jinma 284 Y385 ... and darn I just bought this thing...
Has anyone had to do this job and do you know of any other issues which he might encounter while pulling it apart?
I am ordering the following parts: 8" Dual Stage Clutch Assembly 184.21s.011 approx $390, (that's main clutch and PTO clutch disc), Pilot Bearing 60203 $23, and Throw out Bearing 360111 $38, ...
Does anyone know how long this job should take? Do you think I'll need any other parts? I'm really green here... any wise info is much appreciated...
   / Clutch replacement Jinma 284 ... any info appreciated "How To" video or instruction #2
   / Clutch replacement Jinma 284 ... any info appreciated "How To" video or instruction #3
Re: Clutch replacement Jinma 284 ... any info appreciated "How To" video or instructi
Here's where I split mine with 100 hours on it because of a turned cam bearing: Login Required | CHINESE TRACTOR OWNERS CLUB
While you have it apart replace the roll pins in the throw out bearing forks with a couple of grade 8 (or metric equivalent of 10.9).
Run a tap thru all the threaded holes and replace all the bolts with North American Gr 10.9 bolts that will be loctited in place.
Use Gr.10.9 flat washers and turf the lockwashers.
Be sure to block the front end so it doesn't rotate sideways when you split it.
Gasket between the bellhousing and trans.
Check for leakage from the rear main seal.
Watch for the balls falling from the front driveshaft, I ended up losing one.....Mike
2020 Case IH Farmall 130A Tractor (A50860)
2020 Case IH...
DODGE PICKUP BUMPERS (3) (A50854)
DODGE PICKUP...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A48082)
2005 Northwood...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
71060 (A49346)
71060 (A49346)
