Clutch problems
   / Clutch problems #1
Bill Craig
massey furguson 5445
I have a Massey Ferguson 5445 and the clutch seems to be very sticky after a few hours work.Every time it sticks my shutle forward reverse display on the dash reads a 24 code fault.Can anyone tell me what that means.
   / Clutch problems #2
What's in your machine for a transmission? Syncro-Shuttle, Power Shuttle or Dyna-4?
   / Clutch problems
power shutle
   / Clutch problems #4
How old is your machine? It doesn't have a clutch, just a dampener plate, no normal clutch action. What happens when it faults? Does it stop moving? Is it when you push the clutch in to stop it faults? Does it act up if you don't use the clutch? As much information you can give as possible please.
   / Clutch problems
Its a 2005 model
Whilst engaging the clutch and then slowly releasing it to ease off again, the tractor locks up so that you can't move at all for a few seconds, then seems to release but produces a really large bang kinda noise with a very jerky movement. It means that I can't accurately ease up on to a position. Every time it does this it flashes a code 24 on the reverse symbol on the dash. The problem only seems to occur after operating the tractor for a few hrs but then becomes quite consistent.
   / Clutch problems #6
Sounds like the bottom of clutch switch is heating up & faulting.
As a temporary fix, you can remove the lower dash cowling to allow air to get to it & keep it cool. There is an updated switch to take heat better.
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
