clutch not working correctly?
   / clutch not working correctly? #1
Dying_-2-_Live
1999 Massey 1240
I have a 1999 Massey Ferguson 1240.i recently replaced engine and installed new clutch. without the engine and clutch installed the throw out bearing fully entends just fine. In my backyard mechanic mind things aren't right,
when engine and transmission are mated the engine will spin by hand with the wheels on the ground, no matter whether the transmission is in gear or not. Also, should I be able to push the tractor with wheels rolling with the clutch engaged? I want to be sure the clutch is functioning proper before fully assembling the tractor.
   / clutch not working correctly? #2
My 1994 1250 in gear with clutch engaged turns over the motor. Rolls free with clutch pushed in.
It is manual shuttle.
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
UNUSED WOLVERINE DB-15-84W 84" HYD ANGLE BLADE (A54757)
UNUSED WOLVERINE...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
