clutch noise b2710
/ clutch noise b2710 #1
buddy gregory
if you depress clutch while bush hog is running a loud clanking noise comes from rear of engine . this only happens if pto is engaged .noise seems to be from clutch area . thanks
/ clutch noise b2710 #2
That is the internal PTO ‘OVER RUN’ clutch… Kubota refers to it as One-Way Clutch. It should be more of a ratcheting sound. There are past posts about this and someone has posted about a ‘fix’ Kubota has to allow adding more hydro fluid, it’s an extension to the filler as I recall, more fluid in the case tends to muffle the sound… In any case it is not a problem and is normal on tractors that are not ‘Independent Type PTO’… KennyV.
New/Unused Landhonor Power Rake (A65583)
New/Unused...
John Deere 8345R (A64126)
John Deere 8345R...
Pickup Truck Ladder Rack (A62613)
Pickup Truck...
John Deere 6155R (A64126)
John Deere 6155R...
VAN'S 300 GALLON SPRAYER (A64276)
VAN'S 300 GALLON...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
