Clutch issues?
   / Clutch issues? #1
Bullron
Satoh bull
I have a satoh bull that has lost power in high range and now is loosing power in mid range, is this a clutch issue and if it is can the clutch be adjusted? Thanks for any help I may get.
   / Clutch issues? #2
Usually if a clutch is slipping it will seem to be losing power, usually first experienced in the higher gears. Sometimes adjusting the clutch helps and sometimes the cure is a replacement (which involves splitting the tractor). If you happen to be in the US try contacting Valley Power They are quite helpful and information is free.
   / Clutch issues?
Thanks I Appreciate any information I can get and I will contact a valley power tomorrow.
   / Clutch issues?
Does anybody know if this clutch has a spot to be adjusted ?
   / Clutch issues? #5
I believe the only adjustment is for pedal play. There's a threaded rod attached to the clevis attached to the clutch pedal. Of course if the adjustment is too tight the clutch will slip.
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
HYSTER H55VM STRAIGHT MAST FORKLIFT (A51406)
HYSTER H55VM...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
