3-Point Hitch Clutch engage on PTO
   / Clutch engage on PTO #1
mjp2000
New Holland 1920
We use the tractor quite often but not the PTO. It seems the clutch is more worn for changing gears than the PTO is. When trying to engage the clutch for the PTO it grinds and is very hard to engage. Is there a switch on the New Holland 1920 that can be bypassed so the PTO will engage on startup instead of trying to engage it after the tractor is started.
   / Clutch engage on PTO #2
Disregard. I didn't see a critical word in your post until after I replied.
Keith
   / Clutch engage on PTO #3
I had a similiar problem on my Ford 1710, As I understand it is like a 2 clutch system, on my tractor the PTO clutch was 1/2 engaged from lack of use, a dealership repaired it. Besides being dangerous, I have always been told, you should not backup with the PTO engaged, unless designed for reverse operation,like a snowblower.
Thanks for replying. I have backed up many times with the PTO engaged especially while spreading anti-skid in winter. Many times there is so much ice that the only way to climb a hill is to spread backwards to get up the hill. The 2 clutch system is the problem but the manual doesn't seem to show the access point to adjust it.
   / Clutch engage on PTO #5
Whoever told you that was wrong!
   / Clutch engage on PTO #6
i agree.. this ain't ground speed pto here...
soundguy
Polecat Swift 206R 20ft Towable Boom Lift (A50322)
Polecat Swift 206R...
(1) 250 GALLON POLY TOTE W/ CAGE (A51244)
(1) 250 GALLON...
(1) 24' CORRAL PANELS W/ (1) 12' GATE (A51243)
(1) 24' CORRAL...
2015 FREIGHTLINER M2 DAY CAB (A52141)
2015 FREIGHTLINER...
CLASS ROLLANT 160 HAY BALER (A51243)
CLASS ROLLANT 160...
10' Feed Bunk (A50515)
