clutch doesn't disengage
   / clutch doesn't disengage #1
gauleyrider
ford 2n & case 530ck
Hey yall,
Just found the forum; I'm also a member of ford truck enthusiasts which is like this, so I'm sure some good stuff will be found. Also hope I can help somebody else out once I figure out what I'm doing!:ashamed:
Anyway, I just bought an old 530ck diesel with a clutch problem. The guy I bought it from thought it was the shuttle, but now that I started messing with it I found that the clutch doesn't disengage. When the pedal is pressed, the only resistance felt is from the return spring.
I took off the hydraulic box, where the clutch and torque converter/direct drive linkages engage. The ball bearings weren't jammed, but didn't come out freely. A can of brake cleaner and some lucas got things moving ok.
There is a 1 1/8" threaded cap between the two hydraulic pistons. Inside are some springs and pistons that make what I can only guess as a pressure regulator. The first spring to come out was broken in pieces. The rest came out ok. I replaced that spring with a leftover one from a transgo kit i rebuilt my truck trans with. It was the same diameter and stiffness, but I was only guessing at the length.
Put everything back together and now there's no clutch and no drive :mur: Used to be you could start it in gear to move, but now nothing. I'm looking for a service manual now and the right spring, but any help would really be appreciated!
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
1986 Peterbilt 359 Truck, VIN # 1XP9D29X9GD196948 (A51572)
1986 Peterbilt 359...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
