Clutch does not disengage PTO
   / Clutch does not disengage PTO #1
jasonwdaniell
Gainesville, GA
1998 Kubota L3600/Bush Hog 246 FEL skid steer quick attach
I recently was doing a little bushhog work (which I don't do often enough) and I noticed that my clutch does not disengage my PTO. I made sure that I was pushing it all the way, but it does not disengage. Is this a fix at home type of problem or do I need to consult my dealer? BTW...I have a 1998 L3600.
   / Clutch does not disengage PTO #2
Do a little trouble shooting first. I assume that you have to have the clutch depressed to start the tractor, so I also assume the the clutch itself works. Is this the case? I would visually follow the linkage from the pedal to the transmission and make sure nothing looks conspicuous. After that, I am no help. I don't know what your realtionship is like with your dealer, but I would call them anyway jsut the see what the service manager would recommend that you look into. Good luck.
2013 Dragon Double Rail Roll Off Trailer (A53117)
2013 Dragon Double...
Frontier RT3042 (A50123)
Frontier RT3042...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
John Deere GR72B (A50123)
John Deere GR72B...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
