Close/Open Center
   / Close/Open Center #1
RedRocker
Veteran Member
Bowie TX
Kioti CK30 HST, dual remotes, FEL.
Is a CK 30 hydraulic system a closed or open center?
I have no clue what that is, but CCM want's to know.
   / Close/Open Center #2
You have an open center system. In this system the hydraulic pump is always pumping so the fluid has to have an "open" path from the pump thru any valves and back to the tank/sump. I am surprised Mark Carter did not know this.
BTW, the valve you buy from CCM will need the power beyond sleeve.
   / Close/Open Center
Thanks Mad, I've learned my something new for today.
I've got rear remotes, so do I need a valve?
   / Close/Open Center #4
</font><font color="blue" class="small">( I've got rear remotes, so do I need a valve? )</font>
No..
If you have rear remotes the control valves should already be there.
Small handles/levers somewhere beside the seat controls the valves/remotes
   / Close/Open Center
That's what I thought, thanks.
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2017 FREIGHTLINER CASCADIA (A50854)
2017 FREIGHTLINER...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
