Clicking Noise......Any Ideas?
   / Clicking Noise......Any Ideas? #1
TNhobbyfarmer
Veteran Member
Middle Tennessee
Kubota L3430 Polaris Ranger 500
This is probably going to be a difficult diagnosis, but maybe some of you guys might have ideas. I have a TN75 4wd. I am hearing a random clicking noise. I don't think it is an engine thing....sounds more like from the front steering/wheel area. It's not a steady click, click, click, but more of a random thing. I can hear it either driving the tractor or when someone else is on it. It is still under warranty so I can have it looked at by the dealer, but I think it is something fairly simple, so I would prefer not to lose use of it at the dealer service dept. Does anyone have any ideas? If so, please post......I'm open to all suggestions.
   / Clicking Noise......Any Ideas? #2
Does it click in 4WD or in 2WD, or when changing from 4WD to 2WD or vice versa? Could be your ring&pinion getting ready to commit suicide. I've lost two sets already... and I heard intermittent clicks from the frond-end for a short while before I had real trouble.
Could be a lot of other things too...
...plastic ties can snap back and forth if they're hitting moving parts
...you could have something stuck in your rad fan
...rock in your tire tread or nail in your tire
...poorly lubed pins can click-click just before the retaining bolts snap off
...bent driveshaft cover
   / Clicking Noise......Any Ideas? #3
First thought is loose wheel hardware. Only valid if the noise is absent with tractor stationary. Closely examine or just retorque ALL the rim-to-disc and disc-to-hub hardware. Have not yet seen TN front axle troubles except for one hub seal leak. Look for the simple stuff first.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
John Deere (A50322)
John Deere (A50322)
2020 Kubota SVL 75-2 Skid Steer (A51573)
2020 Kubota SVL...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2013 TOYOTA TUNDRA (A52472)
2013 TOYOTA TUNDRA...
