Clearing trouble codes from 773 Bobcat AHC
   / Clearing trouble codes from 773 Bobcat AHC #1
Vuldar
Penn Valley, Calif.
Bobcat 773
I was having trouble with the AHC indicator would light up and then not. When it was on of course they wouldn't work. I found that a seal in the control box went bad and I replaced it but the code is still bad. My son found out from someone a procedure of moving the handles in a certain order and it would clear them. I was wondering if anyone new this procedure or where I might find it? Thank You Vuldar
   / Clearing trouble codes from 773 Bobcat AHC #2
If someone doesn't chime in, either order a manual or service manual on Ebay or from your dealer. You just need your serial number. Your dealer's service manager should be able to walk you through it on the phone. Even if you didn't buy it there, they should help you.
2016 JOHN DEERE 8245R LOT IDENTIFIER 167 (A53084)
2016 JOHN DEERE...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
